Author Topic: cook stoves  (Read 670 times)
« on: May 21, 2008, 05:47:45 AM »
While reading the thread discussing cooking over coals and fire I thought it would be nice to learn about cook stoves as well. This is what I've found interesting so far this morning.
From The Canadian Settler’s Guide, 1857:
“I would recommend a good cooking-stove in your kitchen: it is more convenient, and is not so destructive to clothes as the great log fires. A stove large enough to cook food for a family of ten or twelve persons, will cost from twenty to thirty dollars. This will include every necessary cooking utensil. Cheap stoves are often like other cheap articles, the dearest in the end: a good, weighty casting should be preferred to a thinner and lighter one ; though the latter will look just as good as the former : they are apt to crack, and the inner plates wear out soon.
There are now a great variety of patterns in cooking-stoves, many of which I know to be good. I will mention a few :—"The Lion," "Farmers' Friend," " Burr," "Canadian Hot-Air," "Clinton Hot-Air;" these two last require dry wood ; and the common " Premium" stove, which is a good useful stove, but seldom a good casting, and sold at a low price. If you buy a small-sized stove, you will not be able to bake a good joint of meat or good-sized loaves of bread in it. If you have a chimney, and prefer relying on cooking with the bake-kettle, I would also recommend a roaster, or bachelor's oven:
this will cost only a few shillings, and prove a great convenience, as you can bake rolls, cakes, pies and meat in it. An outside oven, built of stones, bricks, or clay, is put up at small cost, and is a great comfort. * The heating it once or twice a week, will save you much work, and you will enjoy bread much better and sweeter than any baked in a stove, oven or bake-kettle.”
This passage suggests a cook stove should be in addition to fireplaces. From Rural Architecture, 1852:
“The general introduction of cooking stoves, and other stoves and apparatus for warming houses, within the last twenty years, which we acknowledge to be a great acquisition in comfort as well as in convenience and economy, has been carried to an extreme, not only in shutting up and shutting out the time-honored open fireplace and its broad hearthstone, with their hallowed associations, but also in prejudice to the health of those who so indiscriminately use them, regardless of other arrangements which ought to go with them. A farm house should never be built without an ample, open fireplace in its kitchen, and other principally occupied rooms; and in all rooms where stoves are placed, and fires are daily required, the open Franklin should take place of the close or air-tight stove, unless extraordinary ventilation to such rooms be adopted also. The great charm of the farmer's winter evening is the open fireside, with its cheerful blaze and glowing embers; not wastefully expended, but giving out that genial warmth and comfort which, to those who are accustomed to its enjoyment, is a pleasure not made up by any invention whatever ; and although the cooking stove or range be required — which, in addition to the fireplace, we would always recommend, to lighten female labor — it can be so arranged as not to interfere with the enjoyment or convenience of the open fire.”
Some patents:
http://www.google.com/patents?id=s7NBAAAAEBAJ&dq=3211&num=100
http://www.google.com/patents?id=yitDAAAAEBAJ&dq=4890&num=100&jtp=1
http://www.google.com/patents?id=4wFcAAAAEBAJ&dq=21171&num=100
http://www.google.com/patents?id=2oFqAAAAEBAJ&dq=31489&num=100
http://www.google.com/patents?id=3wkAAAAAEBAJ&dq=38744&num=100
http://www.google.com/patents?id=BAFvAAAAEBAJ&dq=34683%22&num=100
http://www.google.com/patents?id=_NAAAAAAEBAJ&dq=RE2372&num=100
http://www.google.com/patents?id=YWIAAAAAEBAJ&dq=58398&num=100
http://www.google.com/patents?id=v7MGAAAAEBAJ&dq=D3577&num=100
Advertisements:
http://tinyurl.com/4jblfz  (Christian Examiner, Jan – May 1861, pgs 7, 17, 9)
Undated advert: http://library.duke.edu/digitalcollections/eaa.A0456/pg.1/
Later advert but includes testimonials: http://library.duke.edu/digitalcollections/eaa.B0444/pg.1/
Cute videos on different stoves. (I just can’t listen to the audio right now)
http://www.goodtimestove.com/antique_heating_stoves.html
« Last Edit: May 21, 2008, 06:00:50 AM by Anna Worden » Logged
Quilted Hood Pattern - Available on Etsy
Fanciful Utility: Victorian Sewing Cases and Needle-books
hanktrent
« Reply #1 on: May 21, 2008, 06:31:42 AM »
Here's a cute article on the introduction of cooking stoves in a neighborhood:
Does any body know when cooking-stoves began?... The first approach that I remember, was an anciently fashioned "ten-plate," with a place to boil a tea-kettle or receive a frying-pan. The idea thus suggested was subsequently developed, till, as we enjoy our patent, premium, air-tight, or combination, which can roast, bake, boil, broil, and stew all at once, we are convinced that this is truly a progressive age, and we a progressive people, progressive alike in compromises, constitutions, and cookery.
   Some of my fair readers may say, "No cook-stoves! impossible! They never could get along without them." Softly, miss, just step over and ask your grandma. She will tell you how she "baked her brains" over roaring hickory fire--how she fretted about the oak wood, which would pop, snap, and smoke, but would not burn--how she was tried in temper by green beech, or a load of crooked limbs in harvest-time, till she raised a regular domestic row--how, fastened in the left side of the ample fireplace, was a "crane," with divers hooks of varied length, upon which were hung tea-kettle, stew-kettle, and mush-pot--how bread was baked for Sundays, rollings, huskings, quiltings, weddings, and in-fairs, in the brick-oven, and on smaller occasions in the Dutch-oven; and she will also tell you, what I honestly believe, that we have no such bread in these days. She will tell how johnny-cake was baked on a board, hoe-cake on a hoe, and ash-cake in the ashes; also, what a sensation was produced when some cute Yankee brought out the polished tin reflector, which had most pleasing reflections, for they produced luscious pumpkin-pies and deliscious, [sic] creamy bircuit--[sic]such biscuit!...
   But ever and anon came the ominous intimations of what could be done in the culinary department if there was only a cook-stove. The neighbors looked with suspicion and surprise upon such suggestions; they implied dissatisfaction with the lot Providence had assigned us, and then it was putting on city airs. If it came it would destroy primitive simplicity, introduce a new class of artificial wants, would bring in luxury which had already ruined quite a number of ancient notions, and might thus ultimately dissolve the Union...
   The discussion lasted several months, and took a wide range, including, in addition to the political aspect, economics, hygiene, and aesthetics, and was argued objectively, subjectively, synthetically, and analytically. But there was an energy in the kitchen cabinet no opposition could subdue--it prevailed; and it was agreed that the stove should come...
   The stove and its furniture were purchased, and wagoned the forty-seven miles... Its total cost was sixty-five dollars in good money, the transportation ten or fifteen more. It was a substantial stove, containing, in the matter of metal, enough for six such stoves as are cast in these degenerate days...
   The capacity of the stove to prepare alimentary substance was then argued in detail. ...
   That stove seemed possessed of strange intelligence. Let strangers, or especially honored guests, arrive, and bake it wouldn't. In vain did I split the wood fine, and cross the wood; in vain would I fall an ash rail and "cut up the lap," bake it would not...
   Yet, with all its faults and foibles, that old stove had a mission. It is true we afterward sold it for fifteen dollars, yet it did work. It was pioneer. Others followed in swift succession. Soon one of our neighbors reported a better stove bought with twenty dollars less money... One of his neighbors bought the "newest style," with the "latest improvements," and laid out fifteen dollars less!...
   Then came on thrashing-machines, false-teeth, reapers, daguerreotypes, and hooped-skirts. They came after our stove. Noble pioneer! it "headed the column on."...
   But much as stoves are improved, I still think some things are not so well cooked as in the days of fireplaces and ovens. O, how often have I sighed for a good old-times, fireplace-cooked "pot-pie," such as was prepared in those days at rollings! I ne'er shall look upon the like again.... (p. 39-41, "The Pioneer Cooking Stove" T. M. Eddy, The Ladies' Repository, Vol 17 issue 1, Jan 1857, Cincinnati, Methodist Episcopal Church)
Hank Trent
hanktrent@voyager.net
