Author Topic: Linen coat weight  (Read 4281 times)
P McIntosh
« on: June 02, 2015, 01:15:43 PM »
Hello
I'm planning on making a linen frock coat this week. I've got some 6oz and 10oz linen. What weight would be better for a frock the lighter or the heavier linen.
Thanks.
« Last Edit: June 05, 2015, 09:02:41 PM by P McIntosh » Logged
Parker
« Reply #1 on: June 05, 2015, 06:32:16 PM »
Is the weight per lineal yard, or square yard?  If per lineal yard, How wide is the fabric?  I suspect the heavier one would be better, but would like to know the answers first.
P McIntosh
« Reply #2 on: June 05, 2015, 07:13:49 PM »
Its per square yard.
« Last Edit: June 05, 2015, 09:03:36 PM by P McIntosh » Logged
Parker
« Reply #3 on: June 06, 2015, 08:15:52 PM »
How wide is the fabric?  45"?  58"?
P McIntosh
« Reply #4 on: June 06, 2015, 11:36:50 PM »
Sorry forgot to add that its 58.
Parker
« Reply #5 on: June 07, 2015, 06:50:52 PM »
In that case either one would work, depending on how heavy a coat you want.  By way of comparison, the 1865 Quartermaster Manual prescribed wool flannel for sack coats to weigh 5.5 oz per lineal yard, 27" wide.  That works out to 7.33 oz per square yard.  So your 6 oz material would be a bit lighter than Federal sack coat material, and the 10 oz quite a bit heavier.
P McIntosh
« Reply #6 on: June 07, 2015, 11:10:23 PM »
Thanks, its good to know either one will work. This will be my first time making a linen garment so this helps.
Parker
